The Ricoh error code 548 / SC548 is a fusing unit error code. If you are getting this error: Check the fuser unit to see if it is set properly. There are some connections on the fuser unit not making good contact.
Oct 9, 2012
SC 548 - Fusing unit set error or fusing unit installation error,differ to copier models.Try reset by open/close the front door or enter in SP mode and turn ON/OFF the copier.
If I'm not mistaken, that type of photoconductor is not compatible with your particular model of machine. The SC542 and SC548 errors are related to the fuser unit. It is not warming up correctly. It could be that it needs replacement thermostats or thermisters. It's possible that the incompatible drum unit has created this problem.
SC548 is fuser belt rotation error, check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion, I think they have been modified, but I don't have the part number, sorry. Allso check the firmware is up to date.
SC548: Fusing unit installation error - Definition - The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes - • Fusing unit is not installed • Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
this error shows after paper jam on lanier photocopier ld045
