Boot mgr is missing
Boot Manager is missing
If the boot partition no longer can be found, then Vista will display the following error:
BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
Check points for fixing missing boot-manager:
Check that your boot device is configured properly
Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair".
Boot Manager is compressed
If by accident having compressed the entire boot partition, then Vista will display the following error:
BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
OR maybe try this first.
Check points for fixing compressed boot-manager:
If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files.
If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands:
compact /U C:\bootmgr
compact /U C:\ntldr
If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
attrib -c c:\bootmgr
attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
