Televison & Video Logo
Posted on Nov 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv wont turn on
I Have a daijitsu 32 inch tv that when you power up wont go into standby mode (with red light) but goes straight to green light and wont turn on. i have replaced the power board with no luck
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Nov 29, 2013
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15002893
Points
237762
It sounds like a main digital board fault. Contact any service technician. To get more details, http://electronicshelponline.blogspot.com/
5 Related Answers
harjim
  • Posted on Dec 25, 2007
SOURCE: RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Anonymous
  • 58 Answers
  • Posted on Jun 11, 2008
SOURCE: tv stuck in standby
Your problem is in the switch mode power supply or the horizontal out circut.
sometimes the small CHOKE that feeds the base of the horz. out transistor has a cold solder joint.
resolder both ends first.
Thanks Guy9
Anonymous
  • 318 Answers
  • Posted on Apr 29, 2009
SOURCE: tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
ginko
Ginko
  • 19396 Answers
  • Posted on May 05, 2009
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Anonymous
  • Posted on Jun 27, 2009
SOURCE: TV won't turn on
Im similar problen turn on of secon turn off, the probme is cap of 330mf. 200v. is open .
3helpful
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
I have a new LG 32 LD450 TV. When the set is on, there is a green light in lower right. when set is off there is a red light in lower right. should this red light be there all the time, even when set if...
The red light means it's on standby mode but if you wish to turn off the red light you can just go to menu >option>power then choose standby light off.
My ps3 is not working it wont show a picture and when you try to turn it og it goes bip bip bip
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
My sony wega tv will not stay on,it goes on to standby alternating between a green light and a flashing red light.I cannot find the manual. What should I do?
i have a 50 inch wega that i just replaced the lamp. it wont stay on. i lose the pictuer and sound after a min or so then lose it for a min then it comes back on???
1helpful
My t v will turn on, the light will be Red, then Green ,then
your tv in protection mode some thing wrong inside tv.mostly power card defective.
2helpful
Stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
3answers
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
TV wont turn on
my TV does the same thing except it is a Sony
KDF-50WE655
8helpful
3answers
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
3helpful
3answers
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
