If you look at the front dispenser diagram for Whirlpool Gold Model #GD5YHAXTL01, part #4 (the spring) and part #8 (Mechanism Delay) fell out of the ice dispenser and the flap will not close and is loose, so now water is leaking into the overflow pan. Please advise on how to put this back together. Thank you!
SOURCE: Front of in door Icemaker door spring fell out!
Any chance of some photoes may be able to figure out if have some pics.
SOURCE: FLAP ON THE ICE DISPENSOR DOOR WILL NOT CLOSE
look under the disp. cover.you will see 2 cut out were a falt blade screwdriver will fit into it.
stick you screwdriver in that slot and pry out careful not to crack the cover.
tip: press down w/the palm of your hand on the cover while prying up w/the screwdriver.it should snap off
