Stopped running
Check carbon brushes under the black caps on the motor sides. They only go in ONE way so take care, there is a blocker in the square hole on one corner. Line it up with the missing brush corner. If it's not the brushes remove the back cover & check for broken wires. Do your checking with power unplugged.
SOURCE: Stopped running
there is a thermal fuse inside tapped in-line of AC cord .if it was under a heated load it will blow non resettable . need a test meter to check for continuity .electrical flow . with machine not plug in , these items are very small .187 diameter and are crimped in line of AC cord , these are going to cost about $8-10 dls us can be bought @ Radio Shack rating should be about 8-10 amperage , good luck >^.^<
