Two ways - either attach the camera to a spare USB port on the computer with the supplied lead, and treat the camera as a satellite drive, or else remove media device and use a separate card reader to copy the images to the computer.
check any updates of your phone for the software driver and install it to your computer..or betterremove your memory card and use card reader to download pictures or music.
hope it helps
On a laptop you have a built-in card reader. But on a desktop you must have an external card attached to a USB port. If you want to download pics from the card then 1. If it is in a camera already, you attach the camera to the computer via the USB port and from My Computer access this camera and copy/paste the pics that you want. OR 2. Buy a card reader for your type of card and attach it to the computer via the USB port.
attach your phone to your computer, it should come with a usb connector, and software, other people seem to use MPT (Motorola Phone Tools) as their main software.
the USB needs to be placed in a high power USB port for a connection to be established.
Good Luck!
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Once the pictures are on your computer, you can attach them to email the same way you attach any other file.
Camera's usually come with cords that attach the camera to the computer usb. The other way is to buy a card reader that would attach to your computer via a USB port.
You should have a small firewire or mini usb connection that you can attach directly to your computer - simply find the "hard drive" that is your camera, find the files and download to your Hard drive on the computer, preferably straight into you photo handling software or to your desktop
just attach the flash drive to the usb port. when u open my computer, there will be other drives like f: or G:. that is your flash drive. just copy the pics u want n paste it to d flashdrive.hope this works
Take your sd memory card out of your camera, and put it in your computer. A file with your pictures should appear. Copy thoes pictures into a different fold on you computer. Take you sd memory card out of your computer and plug it back into your camera. Your pictures will be both on your camera and on your computer.
I hope this solution helps. Please rate this solution.
