Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
Posted on May 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Pre-owned TEW-432BRP router, when i hook it up to comcast modem i cannot accsess internet. My PC says i have a connectivity problem. The button on front of router seems to do nothing, The lights on front of router,(status&wan) blink intermitingly. Is that what they are suppossed to do? Any help would be apreciated.
JDTec
Level 3:
  • Master 4,338 Answers
  • Posted on May 09, 2009
JDTec
Master
Level 3:
Answers
4338
Questions
0
Helped
2127173
Points
14653
There is a reset button on the back of the router. Push in with a paper clip, till the lights flash. This will reset it to the factory defaults.
Then shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Here is the user guide:
http://downloads.trendnet.com/tew-432brp/manual/ug_tew-432brp.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Hello. I have a TEW-432BRP D1.3R and I usually get close to 10 minutes of connection then it drops the connection and I can't browse the internet. I have to turn the power off and wait 15-20 seconds...
First, check to see if the connection to the TEW-432BRP is not what is dropping signal. If the ethernet line is functioning and you don't lose connection, re-attach the router and try performing a factory default reset on the device. Otherwise, you may want to contact Trendnet support for assistance in determining if the router is faulty. From a hardware standpoint, there are several things on the mainboard of the router that could cause your symptom.
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Connecting two routers to extend network
Router A is connected to the modem. Setup router B to run as access point only. assign an un-used IP address to router B. Turn off the DHCP server on router B. connect a LAN port of router B with a LAN port of router A .do not use the Internet port of router B. do not configure WAN settings in router B. both routers must have the same wireless settings except for the wireless channel which should be different. Set the same SSID and the same wireless security settings on both routers. Good Luck
I have to disconnect and reconnect my TEW-432BRP router
Hi! please try to download the firmware of your router the routers website and upgrade the routers firmware.possible is. the firmware is corrupted..
1helpful
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
2helpful
2answers
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
Trendnet router
i found out that since i have an older version of winxp 2000, i need to get a network adapter, to get this router going.
3answers
My TEW-432BRP doesn't work when loggin yahoo mail or microsoft update web!
what are the setting on the router and or pc and modem? Do you have any firewall or portforwarding turned on? Are you using DHCP?
Need more info...
Trendnet TEW-432BRP
What exactly is the problem? Are you using Cable or DSL internet? Did you connect the cable from the modem to the WAN port on the router and the computer to the LAN or 1 port on the router?
Top Trendware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
