Surefire E2D Defender Flashlight Logo
D
Donald best Posted on Nov 27, 2013
I have a E2d Defender and when I turn the light on the light flashes like a strobe light. Any ideas on how to fix? Thanks
terry l Tusing
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 8 Answers
  • Posted on Nov 27, 2013
terry l Tusing
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
8
Questions
0
Helped
3820
Points
12
THIS FLASHLIGHT SHOULD HAVE THREE DIFFERENT LIGHTS WHEN YOU ACTIVE THE SWITCH TO TURN IT ON.FIRST IS THE BRIGHT,SECOND IS THE LOWER BRIGHT AND THE THIRD IS THE STROBE.YOU SHOULD BE ABLE TO ACTIVATE ALL THREE FUNCTIONS OF THE LIGHT BY PUSHING THE SWITCH.HOPE THIS WORKS.IF THIS DOESNT WORK THEN THERE IS SOMETHING WRONG WITH THE SWITCH.
2answers
Remove light governor
I installed my Hunter Ceiling Fan a little over a year ago. A few nights ago my wife told me the lights in the ceiling fan blinked a few times when she turned it on. Over the next few day the problem got much worse. When I turned on the light switch, the lights would not turn on. After a few minutes the lights would begin to flash, like a strobe light. This flashing would last for about a minute.
This morning I removed the light kit. I noticed the watt regulator, part 98480-02. I connected the wires directly that were wired through the regulator. So far, the light now works fine!
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
2answers
The flash won't fire, and the pilot light won't come on. I've tried new batteries, and that doesn't work. The little LCD screen does have power. I'm wondering if I blew the strobe. Thanks!
Hey i have a 430ex mk1 which when turned on did not fire and red pilot light did not show , i have had the flash since 2006,
i have also tired new batterys and the LCD Light works and the Txt shows up,
did you work out the problem and also how to fix it?
thanks
rick
email
[email protected]
2answers
My hayward colorlogic pool light flashed like a strobe light. After repeatedly turning it off and then on again, it now will flash light for less than a second and then turns off. Spa colorlogic works...
You should check your ground fault and reset if necessary. This particular swimming pool light should cycle through a variety of different light shows by turning the switch on and then off for no more than 10 seconds. If it is not cycling properly, you might be leaving the swith off for longer than 10 seconds or your bulb might have malfunctioned.
1helpful
4answers
My Hayward Colorlogic pool light is flashing like a strobe light
That particular swimming pool light has a power-cycle feature that allows you to change the way your light illuminates your pool simply by turning it off and on. A strobe like effect is one of these power cycles. To change it, simply turn the switch off and then turn it back on within 10 seconds. It should reset to another cycle. It is is left off over 60 seconds, it resets to the first cycle, which could be the strobe. If cycling doesn't solve the problem, your bulb has probably malfunctioned and you are going to have to have a repair tech service it.
I cant use dsc h1 with strobe light
If you problem is that the double flash triggers the strobes early (on the first flash and the shot is made on the second flash - dark) you either:
1. Get a wire accessory to command the strobes
2. Put a simple external flash on top of the camera and use it to trigger strobes. If you don't need the light from this flash just point it up of backwards, it will still trigger the strobes. If it does not rotate, you can use tin foil. A very simple external flash will do, as the camera will flash only once with external flash.
2answers
Orange light help
Did you find an answer to your orange light question? I have an AM4000 defender that I bought off Craigslist and thought I got a good deal on it. One minute after turning it on the red light came on. I tried to reset it but  the red light won't flash so you can't reset it. I don't know if it's a filter problem or a circuit board problem and I don't want to spend $100 bucks on filters to find out it's a different problem. If you buy filters on e-bay, they're cheaper but if you spend $100 from a distributor then you reactivate the warranty. I'm sorry I bought it.
580ex not flashing at all
after using it many flashes at 1/1 power the strobe doesn't work anymore
38helpful
3answers
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Top Surefire Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Surefire Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
