Cd chime reciever ( door bell) I am searching for instructions on how to change the sound on my door bell.
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
SOURCE: my doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
SOURCE: Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
SOURCE: How can I change the frequency on my wireless
Not sure of this model so suggest you give them a call on
01925 712000
SOURCE: 'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
SOURCE: My Desa Specialty doorbell doesn't ring..I have
Batteries are located in the doorbell push button case in the back. Slide open a compartment to reveal the batteries.
