I recently contacted Hunter and they said the loud motor in the Hunter 34357 humidifier can NOT be replaced. Instead, they can provid a pro-rated refund, depending on how long you have owned your humidifier. A receipt from your purchase is needed to get a refund. Contact Hunter at http://www.hunterfan.com/Support/Contact-Us/
SOURCE: Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Try white vinegar instead. The same type of scale builds
up in drip coffee makers. Most recommend white vinegar to remove the scale that
builds up over time. The added bonus is it costs less and is completely safe. If your unit is a water over paper media humidifier, you would be much easier to replace the paper media.
