SOURCE: Maax Shower door. We lost part manual. Where can
contact their website. I did that for an LG tv. They sent me an e-mail of the pages i needed and mailed me a new full tv manual.
SOURCE: How do I install maax corner shower doors?
Here it is...
Be patient it is a large pdf file...
http://www.maax.com/Upload/docs/premium/technical/en/000_10014442_0904-2_E.pdf
heatman101
SOURCE: I need to remove the Maax shower base and can not
Hello, You shouldn't have to resort to that extreme. The drain unit that the retainer sits in is the part securing the base down, have a look at the diagram in this link: http://www.maax.com/Upload/docs/premium/technical/en/000_10014442_0904-2_E.pdf
The drain assembly should unthread and release the base. But sometimes they tend to work as designed.
The retainer is a compression fit (or should be... do you know the installer? they may have deviated from the described installation). Assuming a proper install, use a flat-head screwdriver and a utility knife to seperate the inside portion of the rubber seal of the retainer, from the plastic ring. The ring should now be able to be pried out, and the drain portion unthreaded.
If this helped, please rate a four-thumbs up. Thank You.
