I just recently started using my cammera with the manual settings, And have been gettings some really great pics. I was getting pretty decent night time pics in the house but someone recently messed with my cammera and I dont remember what the settings were. Can any one help here. Also I can take a pic in a totaly dark room (if I find the settings again) but hardly any thing comes out out side. Any advice. would an external flash help any??? Thanks for any help. Joanne
SOURCE: need help with Kodak CX7530
The first thing you need to determine.... Is it your or the camera? You need to take a series of shots with your camera sitting on a tripod. If you do not have a tripod, sit the camera on a solid surface. ................... Camera movement is the number one cause of blurred photos. A few tips: 1. When you punch down the shutter button ... that can move the camera just as the picture is taken. Dont ''punch'' down the shutter button. Hold the camera in such a manner that you are squeezing the shutter button between your forefinger and thumb. 2. When you are using the LCD to frame the shot, you have your arms extended in front of you. This invites camera movement. Instead, use the viewfinder and make sure that the camera is pressed against your face. Your head is steadier that two outstreatched arms. For added stability, lean your shoulder against a pole, tree, building, or other solid object. 3. When taking flash pictures remember, that flash only covers so much area. The CX7530 is rated for 11.8 feet if you are not using optical zoom. It is rated for only 6.9 feet if you are using optical zoom. If your subject(s) are beyond those distances, you will get a dark photo. 4. When shooting in dim light and not using flash, the camera will select a slow shutter speed. You must use a tripod or sit the camera on a solid surface.
SOURCE: transfering pics from camera to pc
Use the cord that came with the camera and plug it into a usb socket. make sure the camera is on and set to the upload control. Windows does the rest. Also the manual in a more comprehensive form is on the software Cd in th PDF file.
SOURCE: no more flash
when i dropped my dx7630, a tiny plastic part broke that worked the holdback spring for the battery. Kodak has a repair service, or a referral service for repairs, but you have to send the camera in. i sent it in. they emailed me to say it was not a repairable part and didn't even ask if i wanted it back. luckily, i kept the memory chip. my C875 was $100 cheaper and had 1M more pixels. good luck with your natural light photography from now on. i think Kodak just figures you buy a new camera whenever anything goes wrong.
SOURCE: lcd
what did you turn on for the screen not to come up?
Camera or PC
More detail information if you please.
