Question about Polycom SoundPoint IP 331 IP Phone
Not able to pick incoming call
Incoming call calls: I can make outgoing calls and I can hear ring tone for incoming calls, but when I try to pick the call it doesn't get connected. Line 1 flash light just blinks and Answer Button is still active. I see other option to reject the call and if i press that button, the call gets disconnected...
    Master:
  • 335 Answers
Please tell me what kind of phone.
Posted on Dec 21, 2017
2 Suggested Answers
SOURCE:
  • 7 Answers
SOURCE: I have a polycom ip 501 and when it rings and I
there is a setting in the config files i beleive you can also go into the ip addrss of the phone and set it to auto answer or something
Posted on Jan 09, 2011
For incoming calls the phone rings but I cannot hear the caller. The volume is set to the maximum. For outgoing call I cannot hear the ring tone nor the person receiving the call.
Sounds like you reciever speaker is out. It might be cheaper to get a new phone than fix this one. Check with out a local cell repair store to see what they charge then make an informed decision.
Sep 30, 2010 | Nokia 6131 Cellular Phone
Dropped it - put battery back in. Works for outgoing calls but only vibrates, does NOT RING for incoming calls. Checked Settings--> Ring Styles and changed to Loud (still doesn't ring) and back to Vibe...
You dont hear tones after you dropped it.
This is because the speaker connection may be disconnected due to sudden ****.
You need to contact your authorized motorola service centre to fix this problem.this is a very small problem so no need to worry.
Thank you
Aug 08, 2010 | Motorola Mobility RAZR V3
Phone sees call, but can't pick-up. Can't get d-tone to call out?
Just a suggestion (without knowing what troubleshooting steps from your manual you may have taken): Remove the batteries from the back of the handset and then put them back in after a few moments. My Panasonic KX-TGA8231B (DECT6.0) phones were acting up just like your Uniden is. All functions returned after this power interrupt "reset" with the batteries was done. Hope that helps. Good luck. - - -Gerry
Nov 30, 2009 | Uniden TRU9485 Cordless Phone
Nokia N72 mobile phone, am unable to hear dial tone when dialling and unable to hear incoming call answering a call and unable to from them when I make outgoing calls.
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Jul 11, 2009 | Nokia Cell Phones
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
Jan 23, 2018 | HP OfficeJet 6210 All-In-One InkJet...
Not responding in Incoming & outgoing
MY HTC PHONE NOT RECEIVING INCOMING CALLS SOME TIMES I HAVE AIR-TEL SIM CARD FROM (ANDHRAPRADESH)
Jul 07, 2008 | HTC Touch P3450 Smartphone
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
Incoming calls
Try to reset the unit with the phone again.
Feb 25, 2007 | Motorola Mobility H500 Wireless Headset
Polycom SoundPoint IP 331 IP Phone Logo
46 people viewed this question
Top Polycom Computers & Internet Experts
N8nNc
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
