Bought new batterys went fine now when I sit on seat green light flashes if I stand up it works again
Sounds like you are sitting on some of the wiring or connectors, take it apart like you did to fit batteries and check there are no wires shorting out or connector is being squashed, check as you put it back together, you should sort it that way. the error code should be:
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
so check these wires and connectors closely first.
but please note that with out the make and model the error code is the most lightly posability.
SOURCE: scooter motor does not operate
are you sure its in gear. I had the same problem and I pushed the nob on top of the motor towards the front of the machine and it worked!!!
SOURCE: Green light flashes 9 times will not go
Hi. Different brands of controllers give different fault codes.If this is a dynamic controller, 9 flashes is the code for a faulty controller. This does not always mean that the controller is actually at fault.
It could be a burn't out brake solenoid, that now has a different resistance through the solenoid coil.
You mention the middle speed green light is flashing, normally on dynamic controllers, it is the most left battery level LED that flashes. You might have a different controller.
Have a look under the panels and let us know what controller your machine has.
You could try the agents, and see if they can tell you what the problem is.
Good luck. Neil.
