following these steps
1. double check the batties
2. to go remote and double check to make sure that it getting electric
3. double check the circuit breaker, sometime you have to throw the switch off then on again if it tripped.
4. Call a electric you might have a bad circuit breaker or a short.
If you can't clean the connections. It is no longer supported by Hasbro. You might try a local small appliance repair shop if you have one. They may be able to clean/repair the battery holder to return it to functionality.
Next time this happens. Look for a light on the dash that says "security". A common failure on GM vehicles is the anti theft security system. When this system is not working properly, it will immobilize your starter. This problem only gets worse. If you see this light, go to this link for helpful info and some "do it yourself" solutions.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
