The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful)
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
Switch your Digital Multi meter to DC AMPs. Amps is usually indicated by an "A" on the Multi meter Switch. AC is usually shown as a "~" symbol and DC shown as a "-" symbol. You usually have to move the multi meter positive lead to a separate socket on the multi meter to check for amps. Sometimes there are 2 sockets, (a high range and a low range). Always test on the highest setting first. For example: High setting on your multi meter may be 10 Amp. Test on the 10 Amp setting first, then if the current drawn is less than your Multi meter's (low setting) move to that setting and keep testing. For example: On my multi meter the low setting is 0.3 Amps. Also indicated as 300mA (mA x 1000 = A).
Remove the battery's positive cable.
Connect the multi meter's positive probe to the battery's positive post while simultaneously holding the negative probe from the multi meter up in the air, to keep it away from anything metallic.
Place the negative probe of the multi meter on the end of the removed positive cable to complete the circuit.
That's right, you're putting a negative on a positive, but its ok, because if the drain is severe enough, you're most likely to blow a fuse or two, which will identify the problem area.
Above I said to remove the positive battery cable because that is the way I do it. You can do the same test with the negative battery cable removed. In fact for you that may be a better way to do the test, because there would be no way for any electrical issues to occur by accidently grounding the negative probe from the multi meter. i hope you understand what I'm saying here.
