How can I tell for sure that inject pump on a 555e new holland backhoe is bad or good
You have to have your injector pump set at tdc by dealer or shop that deals with delco injector pumps. You set engine at 28 degrees btdc compression(marks will be on flywheel you can see through inspection hole) and then install pump tighten gear bolt then unlock injector pump,
