My grandson's hand hit the remote while he was laying on the floor, putting the TV in the sleep mode. The TV timed out, powered itself down, and now will not turn on using the remote or the main power switch on the TV. The red light that is located beside the power button is on indicating that there is power applied to the TV set. What is needed to power the TV on. Is it a password or sequence of buttons being pushed or what?
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
My tv screen diplay blue screen and donot operated manually or by remote what are the probable causes and remedies?
Thank you greg-margo for the advice. Unplugging the tv set for a few minutes like you recommended worked. Have a great day sir ... jp
