How do i test the rectifier regulator on 1981 1100gl?
out put side use multi-meter attach black lead to (dc) out lead of the rectifier.Attach red meter lead to an AC lead , forward bias reading should be 0.3V-0.8V repeat for each AC lead.Now reverse the meter lead hookup, reverse bias readings should read OFL. To do the ground side.Attach black lead to AC lead, Attach red lead to rectifier ground lead 0.3V-o.8V check all AC leads .Reverse the meter lead hook-up all rev-bias should read OFL if any of your readings are not within specs. replace
