Cell Phones Logo
Posted on May 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to open pics taken from my mobile camera in my pc wen i transefr them in computr thrugh usb cabel wire
When i take pictures from my samsung omnia i900v, n transfer them in my pc through usb cabel wire, the pictures doesnt open in pc, n say no perview availble bt they show preview in mobile bt nt in pc
Anonymous
Level 3:
Master:
  • Master 497 Answers
  • Posted on May 08, 2009
Anonymous
Master
Level 3:
Master:
Answers
497
Questions
0
Helped
221236
Points
1118
I guess ul need a pc suite for ur omnia installed in ur comp first
Thanks for using Fixya
3answers
I want to download pics from my Samsung Omnia pro 7330. I have a data cable connected to my laptop but i do not see my laptop sensing the mobile phone. How do i download the pics? I have a nokia too. and...
Go to settings of your phone then choose USB data connection. Then choose Mass Storage. Don't click the PC Suite because it will took longer time to upload photos from your phone
1helpful
Can i use Samsung omnia i900 windows phone as a modem to connect to intenet?
1. install the Samsung Omnia modem driver on your Windows PC - can be found @http://www.samsungmobile.com/promotion/omnia/fr/sub02_xp.jsp
2. if you have installed Active Sync on your Windows PC then make sure that before you connect your mobile device to PC you disable "Allow USB connections" from the Active SyncOption menu
3. after you connect Samsung Omnia to PC, on your mobile device go to START->PROGRAMS->INTERNET SHARING and select the connection type (bluetooth or USB - most commonly used would be USB); tap "Connect". Your Samsung Omnia will connect to the mobile network if you have set up a profile for GPRS/HSDPA according to your billing plan provided by the network operator.
3helpful
I want to change my i900 samsung 16 GB language to english
Hello thanks for using Fixya
To Change the language to English of Samsung SGH-i900 OMNIA. Follow the given instructions
1. First of all Download Samsung Omnia Operating System ZHHH2
2. Now hold your OMNIA in your hand Press the Dial key to the left of the optical pad to bring up the dialer. Keypad will open
With the onscreen keypad press *#1546792*#
Now Select "Preconfiguration"
Now enter code *#81230*# and select OK
Select "Hong Kong" with the default Operator
Accept this, DEVICE WILL HARD RESET
3. Now open i908ZHHH2_ENG from download folder which you have downloaded in step 1
4. Turn off the Samsung SGH-i900 OMNIA
5. Connect the OMNIA to a PC using the usb cable
6. Turn on the OMNIA
7. Click start button if the device found & wait for job done message
You have done it
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
I have no Genuine USB Cabel to Connect the Camera with PC!
Use a card reader to download your pictures to a folder you create on your desktop.
2answers
Lost pictures on omnia
Go to gallery first. If not there, then press START-Programs-File Browser. Look in the folders (mostly My Documents-Pictures or My Pictures,or Camera-DCIM).
2answers
Hi i buy yesterday sAMSUNG L100 AND I CAND'T DOWLOAD PIC ON MY PC
-turn the unit OFF
-CONNECT the unit to your PC
-TURN the unit ON
-a selection should be displayed
-pick COMPUTER
-the computer should detect the unit as a REMOVABLE DEVICE
-open REMOVABLE DEVICE
-open DCIM folder
-there should be folders inside DCIM named SSCAM100, SSCAM 101, ....
- your pictures should be inside those folders
*each folder consist of 100 pictures that you have taken
*the camera automatically creates each folder for every 100 pictures that you have taken
hope this helps
Help Please
there is two ways to load pictures from your cam to pc:
step 1
youll need a card reader to put in the memory card to a usb port.
A.then the computer will recognize the device as a FLASH DISK/ REMOVABLE DISK.
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "flash disk/removable disk" and click.
C.once inside find the DCIM folder this contains your pictures taken from your cam.
D. now you can choose a picture you like to be transfered or copy to your PC
E. save picture in a folder that you ca easily remember
step 2
need a usb wire to connect cam to usb port
A. attach wire from your cam to usb port/pc
B. your cam will show options choose storage data. the other options requires a software
C.same as step 1 from B-E
i hope i was able to help you with your problem! good luck!
I cant upload my pictures to a mac computer
see first urs usb cabel is well fitted in urs pc or not or wid camera.....
if it is fittd well n u r unable to transfer ur photo.....then restsrt urs pc n camera at sm time n see it connected or not....
if all off these methods r useless then transfer urs photoes by using card reader...... but usin carrd reader u can only transfer urs memory card pics...
n also check urs usb slot in pc by attachin urs mobile or ny other device...it works or not....
ask me if it creates more problem.....
thanks...
Memory card
Just connect the camera to PC with usb cabel or use some card reader. there will new removable disk icon appear in windows explorer (if using windows) or other file manager. Then just copy the  fotos to PC.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
