I hope I am correct in thinking you need to know what kind of battery you need for your thermostat and how to replace it. If so . . .
Do you have a set of printed instructions on using the thermostat tucked away somewhere? If so, go find it. The instructions should state the kind of replacement battery you need and how to go about replacing the battery/batteries.
If you add the maker of your thermostat by clicking or tapping on Comment and typing in the manufacturer name, I or someone else volunteering to answer for Fixya may be able to find the instructions for you.
Hello sir,
honor to make you know that GNM-OTE3 is not a valid model of jabra products.
try to identifie your product first
you can post a photo for it and I can help you in the future.
Bye
1. Put the headset in pairing mode and make sure that the
headset is on. To do this: Press the answer/end button and press the volume up
(+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra headset
(Follow your phone’s instruction guide to do this)
3. Once your phone locates the headset, it will ask you for
a code to pair with it, the code for jabra headsets is usually 0000
hold the answer button and the power button in for 5 seconds until you get a solid light, then add device to your phone and follow thru with the pairing procedures as prompted on your screen
1) Charge the headset (plug it in until the LED light turns off. Didn't take very long for me) and unplug it...
2) Make sure the unit is ON (It blinks quickly when powering on and off, and blinks consistently while on, so it shouldn't be hard to tell) [the power switch is very slim and on the outer edge of the unit, labeled by a circle with a line in the middle]
3) Hold down the big silver button on the large outer flat surface of the unit until the LED light *STAYS ON* ***While that LED light remains solid, the unit is in Bluetooth "Discoverable" mode*** After you have put the hands free unit into this mode, then *promptly* follow your own cell phone's blue tooth pairing instructions, usually found in the "tools" or "settings" menu.
