Beeps 4-5 times then goes into a dial tone and works normally. it is trying to tell me something. I have no messages-all are deleted and it still happens... Why?
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
SOURCE: The VM indicator displays on my handset but there are no messages
I saw that someone else posted this solution and it worked for me. Unplug the power on the base unit and then reconnect the power while holding the "find hs" button. I just did this and it fixed my blinking light problem.
SOURCE: When I get ready to dial, phone beeps 3 times
You must have an answering service from your phone company, and probably don't know about it. Try dialing your own # and wait for the prompts.
SOURCE: Has new battery, but no dial-tone,
Replacing the battery reset the phone to the factory defaults, which means you'll have to restore the connection to the base in Menu-Setup
***Don't forget to VOTE for the guys who take an interest in helping!
