Dryers Logo
A?albj?rg ?lad?ttir Posted on Nov 25, 2013
Child lock Can not start - picture of lock
Smitty
Level 1:
Champion:
  • Contributor 240 Answers
  • Posted on Nov 25, 2013
Smitty
Contributor
Level 1:
Champion:
Answers
240
Questions
0
Helped
66246
Points
50
May I please have your model number so I am able to provide you with accurate, model specific information?
How do i unlock child lock on a Siemens washing machine? Model: WM10S740EE
Hi there
Some are different ways. but you can try this.
If you want to activate the child lock function hold down the Temp. and Spin or Rinse buttons at the same time for 3 seconds. Click here to view a simulator showing you how to use the Child Lock. When the child lock is activated only the power button works.
========================================== or
  1. 1 However, Child Lock does not activate until you press Start/Pause.
  2. 2 Child Lock does not activate until you press Start/Pause. In the holding state, you can open the door or change settings by pressing corresponding buttons. However, once you press Start/Pause to start the washing machine, the Child Lock will be reactivated.
    Can only try
    All the best Clive
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 • AEG Dryers
Unlock child lock
On the Audi Q7, depending on country and options the child lock is either:
1. On the drivers armrest, near the window switches, there are 2 buttons with a little orange light and a picture of a little baby on them. Deselect both buttons to turn off the child locks.
-OR-
2. Open the passenger doors, there is a small keyhole on the inside of the door above the latch, use your key and turn it 90 degrees to turn off the child lock.
Hope that helps
Child proof lock is on and dont know how to turn it off?
Child Lock is activated. Look for a picture of a small child's face on the Facial Panel (usually with picture of a lock) follow the arrows to 2 buttons, press and hold these buttons for 5 - 7 seconds. Child Lock will then deactivate.
Hope this helps
* If you found this solution helpful, please vote positively.
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
I am trying to start my washer and the symbol of a head with a collar appears on the dial and i am unable to change any of the controlls or start the washer.
Hi.
Samsung machines error codes are numbers and letters, then I the machine is not in fault mode, but child lock has likely kicked in.
Here is child lock icon:
Try the following:
ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal
How It Works:
1. "Child Lock" can be activated while your Washer is running.
2. Once you activate "Child Lock", all controls (except for the Power button) will be locked
until you deactivate "Child Lock".
3. The Child Lock button will be lit while it is in effect.
Here the user manual.
I am babysitting at my daughters house and I have the loc light on and I cannot get rid of it. I am trying to start the dishwasher and cannot get it to go.
look at the control panel there is a button that has a picture of a lock or a child by it, that is your child lock button, hold button down until lock light goes off
4helpful
2answers
How to remove child lock on rear doors?
Show me how to take the safety child lock off switch also I need a picture of this location on the door
5helpful
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
