You can normally find a coffee pot cleaner in your local big box store (Walmart?) if not try running a cycle using vinegar rather than water. If that does not clear it out try unplugging the machine and using a bottle brush in the tank then turning it over the sink to dump out the slime. Be careful not to get water all over any of the electronics.
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
SOURCE: Bunn coffee maker reservoir makes a gurgling noise
THis sound is usually caused by the water being low in the tank. This can be because the machine is left on for long periods without being used. If this is not the case, then it would probably be your heating element getting small holes in it.
SOURCE: Bunn Coffee Maker Leaks out the bottom
Hi I have had this problem twice....this time I took off the top of the maker to check it out and noticed something loose and this fixed the problem, on mine at least. Lift the lid and take out the two Phillips screws, and remove the grid. Take out the three (or four) Phillips screws on this level and remove the top of the maker. There is a tube, with a hex nut around it, under the swivel arm that shuts off the water when the lid is up. On my maker this nut was very loose, even though the seals were still good. I tightened it with a pair of pliers( don't over tighten) and it hasn't leaked since. I also cleaned the water tray out while I was at it , as it looked rather yechhy. Reassemble and put the screws back in (don't over tighten, as they are in plastic)
