Printer has error c2555 call a technician. how can i reset it
Replace the yellow image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Printing from an IBM AS/400 to a Konica Minolta 350 printer
An HP5si PCL5e driver may work for just basic printing.You will not have any extras like finishing or dulpexing.
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
SOURCE: Konica Minolta Di2510 error code C0500,can not
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
To improve paper-feeding in the paper take-up section of the document feeder some adjustments have been newly made. Please ask a technician for this updates, but the error code suggest binding in the lift motor (may need to be replaced) or the lift plate is not producing enough pressure.
