My computer is on, and it beeped, yet i am unable to view the screen.
Yup the problem is the ram memory if you have more than 2 memory cards remove one and try it if you have four like i do and see nothing on the screen chances are that 1 or more of the memory cards are damaged. Also check the 4 pin ATX power plug if that fails your puter will start but you wont see anything on the screen. Goodluck
You try to replace the RAM
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
