I tried the grease cutting soap to no avail. Decided it needed a more aggressive approach. Since the suggested cause was grease, I decided to try my automotive brake cleaning spray. That did not wash the surface but it did soften the surface enough to discover the culprit was a deteriorated coating Farberware put on the handle. The brake cleaner was effective in softening the coating such that I could use my finger nail to scrap it off. I now have a smooth non sticky handle.
SOURCE: How to clean sticky ceramic fry pan
DO YOU MEAN A CAST IRON PAN OR NON STICK? If it is not stick you have to use a chemical that will remove glue from any object and then rinse well. Do not scrap. Let soak in for about 15min. and then scrub with a kitchen dish scrubber. This may help.
