It's worked perfectly for years. We are no longer able to turn the knob which controls speed, etc. The knob is about 2 inches in diameter and only protrudes about 3/8 inch - so difficult to grip. Any suggestions?
The control & pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system will include the following items:
· New Pump
· AirStreme Control box and topside control
You will change out everything from the old system with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/0108-205005.aspx
US Parts Center
Testimonial: "The pump itself works fine. Turns out the actual knob rusted out which is why we couldn't turn on/off. The knob was the only thing that needed replacement."
SOURCE: four inch crack in the bottom of aquaglass tub styren
CONTACT COMPANY THAT FIX CRACKED CAR WINDSCRENS, THEY CAN PUMP A POXY RESIN INTO CRACK .
I dont know if you still have the aquasense controller knob but I would gladly buy it from you if you do.
