I need to replace the light and have no manual for this oven. It doesn't seem to screw undone, nor does it push in and turn... how on earth do I do this without wrecking the oven?
my oven brand is a Simpson Evolution 800 Electric Wall Oven - (dunno what happened to this piece of info in the original question!)my oven brand is a Simpson Evolution 800 Electric Wall Oven - (dunno what happened to this piece of info in the original question!)
AnonymousNov 27, 2007
I have the same problem with the oven light in a NEFF Circotherm oven - model not known but is stamped GB-1051.01HOS 1051-SP on the type plate - I have tried a little gentle persuasion with flat bladed screwdrivers under the edge of the glass but am very reluctant to use any amount of force. The oven liner appears to slide out [if the hinges are removed] but I hope there is an easier way to get at the light fitting. Many thanks for any assistanceI have the same problem with the oven light in a NEFF Circotherm oven - model not known but is stamped GB-1051.01HOS 1051-SP on the type plate - I have tried a little gentle persuasion with flat bladed screwdrivers under the edge of the glass but am very reluctant to use any amount of force. The oven liner appears to slide out [if the hinges are removed] but I hope there is an easier way to get at the light fitting. Many thanks for any assistance
My oven is a Neff U1421 and I have the same problemMy oven is a Neff U1421 and I have the same problem
AnonymousMar 24, 2009
I have a Crosley oven and I can not get the glass cover off the oven bulb to replace it. Does it turn or pull off? It does not have a wire that holds it in place.I have a Crosley oven and I can not get the glass cover off the oven bulb to replace it. Does it turn or pull off? It does not have a wire that holds it in place.
You can't post conmments that contain an email address.
Unscrews anti clock wise dont lever glass (like i did) with a knife it breaks. the metal bit that the glass screws into will spin thats why it wont undo.
I Also have a wall oven by preway in a 1955 spartan trailer, basic same problem, I am told the control assembly that you turn to set temperature needs to be replaced, if it is adjusted to far on some part behind the controll knob it will screw up the new one also, Spencers appliance in Portland Oregon worked on mine years ago and was able to get parts, Good Luck
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
If there are no screws at the rear of the oven compartment that you can see to remove, then you will have remove the oven from the housing, and remove outer rear panel of oven to access the element.
Check the 4 fixings again, because on some ovens , they are not using coventional screws, they are are using what are called Torx screws, and you need a torx screwdriver or key to undo them.
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
You need to remove the whole oven from its cabinet (after switching off the electricity supply). Removing the doors first;
(see http://www.youtube.com/user/Apart4u for videos of this)
then remove the facia, which allows you access to the two restraining hooks near the top of the sides of the oven. With these slackened off (screws at the front) and pushed back, the oven can be slid out of its housing - be careful, it's heavy - onto a similar height workbench in front of the oven housing. Removing the wiring hatch (2 screws) and the rear panel (6 screws) gives access to the screw in bulb.
Hope this helps :)
