SOURCE: Compatible Graphics Card for ASUS P5LD2-VM SE Motherboard
Your board is PCI EXpress so as long as you get a PCI express Video card you should be fine. Just dont get a video card with a Faster Bus speed than your Mobo or else its wasted potential, but other than that, ** problem, have fun playing video games :)
SOURCE: graphic card slot for asus p5ld2-vm/s
PCI Express X 16.
Here is a link to the user guide for additional info:
P5LD2-VM Manual
See page 1-20
SOURCE: asus p5ld2 connect to front panel
The front panel connections are on the same side as the SATA connections about halfway down the board on the edge. They should be labled in small print. Hope this helps & please remember to rate my answer. Thanks.
SOURCE: I Formated my pc windows XP and I can t connect to
Make sure your network adapters are working (wireless or wired). Go to Start -> Settings -> Control Panel -> Network Connections.
If you are using wireless, right click on your wireless adapter and chose Properties. If your network SSID is not there, click on Add and make sure you enter your authentication type (WEP/WAP/WAP2) and passcode that is the same as your network.
NOTE: Please rate our help to keep this free service online.
