Televison & Video Logo
Anonymous Posted on May 07, 2009
Sanyo tv 21dn2
Does anyone have the tv or a manual for the remote, i have just been given the tv and can not manage to get the menu up on screen to be able to tune in the channels can anyone please help?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
77
Points
Hi
FREE online manual to download directly from here
http://uk.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/CRT%20Television/21DN2.pdf
Why put a menu button on a remote and then disable it , it does sweet FA :)
Sanyo instruction manuals
Most universal remotes don't have all the functions of the original remote controls.You may be out of luck unless you can find an original remote. There are web sites that sell original remotes. Just Google TV parts stores.
HOW TO PROGRAM A SANYO DP32649 TV WITHOUT REMOTE OR MENU BUTTON
You may have a manual MENU button on the side of the TV that can give you navigation through the MENU windows on your screen. Check the TV or manual.
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
3answers
My sanyo tv doesnt have the remote and i need t adjust the screen so that i can see the whole picture
U can't do these kind of adjustments without the tv original remote sorry.Try website like Remotes.com to buy the tv original remote to used.
2answers
My TV is stuck on Video with a blue screen. Is my
Change the input to cable or TV. Look in the manual and use your remote to scroll through the menu....
No menu on screen
on your sanyo remote press menue button
1helpful
I need help with my sanyo tv, Do I have to buy a sanyo remote?
Try code 049 . It worked for my GE Universal remote.
2answers
Manual Controls Not Sufficient
If you have a "Menu" button on the front panel of your set, then you may be able to change settings from the menu this way. If not then you will have to have the original remote to change settings. Stargazer
2helpful
TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
