Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Dead set, Akai 42" Plasma PDP4294, no power
Looking over very big and very complex SMPS board, all SMD fuses are good and main 8A line fuse is good, no shorted switching transistors or diodes found, no bulging caps.... any helpful suggestions or common failures would be a big help, thank you.
Akai PDP4294 (Samsung built?)
electricitym@yahoo.com
  • Anonymous May 07, 2009
    It's a wonderful day.... Ahhhh, it is now FIXED and working great. I found cracked solder joints on a few of the switching power transistors and some of the big diodes and other heat producing parts. Also notice that the infamous Red caps C524 and C523 were discolored but they checked OK on my cap meter and also my ohm meter, however while I was inside the set after removing 1 million scews I decided to replace them anyway.
    I hope that my repair success helps someone.
    electricitym
Porblem solved,
electricitym
Posted on May 08, 2009
SOURCE:
I need a transformer for my 42" akai plasma screen
On what board and what transformer? Power, standby, Driver????
Nov 27, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai 42 in. PDP4294
The high voltage power supply for the plasma display has failed. It may or may not be on a separate board that could be replaced the owner. If you find a separate board, it may have its own fuse which you could check for continuity with an ohmmeter.
Nov 28, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No Picture on PDP4294
Normally the sets have seperate power supplies for the input/main logic board and the HV which drives the panal (could be 2 parts on the same board). It sounds like you have a problem with the power board that drives the panal and HV. Check to see if any fuses are blown, if the fuse is blown, you can try replacing it, but if it continues to pop, then the main fets that drive the HV are shot and will need to be replaced.
Apr 13, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294
Repair service for power board B4K-50:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110646032176
As stated in the listing there please note that there are unique board components that are not replaceable...so depending on the failure there's always a risk that the board may not be recoverable.
Apr 07, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai dlp
i have a similar tv, with 5 blinking red lights on the power off. is that a power board issue? (I see the small green light ionside the tv, flashing green.,,) the outer light stays red or flashed red when i power off. i replaced the fuses, still same issue.
Mar 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Plasma TV - won't turn on
well, there is no fuse box. it's a small, 20mm fuse, tere is one on each board. just remember what screws you take off where. take pics along the way, draw yourself notes. inside it's like home computer, just boards and screws. probably fuse or the power supply board itself.
Jan 08, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
DEAD
Check the cable to see if it might be damaged.
There may be a fuse inside, but you should not open it yourself. Any lights on when power is connected?
Nov 07, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Testing the BN96-00249A power supply in an Akai PDP4294
You can get the schematics for the bn96 00249a smps here in pdf format. http://www.wimtv.be/techniforum/files/ps42p3sx_ch._d58a.pdf
Jul 23, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
253 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
