Refrigerators Logo
Anonymous Posted on May 07, 2009
SubZero 532 (1994: Top of refrigerator just inside the frig door
Top of refrigerator just inside the fridge door
has condensate collecting and eventually dripping onto the floor. I ''inherited'' this fridge from previous tenant who SWEARS that it is was caused by a missing part from the door hinge, and that it was a simple matter to fix.
Someone else told me that this part very often
''breaks off''. But both those folks have disappeared, and I can get no more info on it.
HELP !!! What part is it? How much is it? Can I install it myself? (I'm handyman-challenged, so to speak, but I'm willing to try
it if it's easy....
Does any of this make sense to anyone?
Help !!!
Dan S. in (what's left of) ''Dah Bigh Eahzee''Comment posted on May 07, 2009
Howdy.
Thanks for the quick reply.
Model was 532 manufactured in 1994...Comment posted on May 07, 2009
Oh, yeah. Did I mention it's a SubZero (model # 532)?Comment posted on May 07, 2009
P.S.
Door does not close all the way by itself. The top of the door's interior white plastic door shelf ''rim'' does just barely graze the
inside of the fridge at the handle side, but hardly even noticeable.
There are no other noises to speak of.
As regards a ''cam'', that may be what the prior owner was referring to when he said that the door hinge was ''missing a piece'', and that the lack of that piece was causing the problem.
However, I do not see a ''cam'' on the other (freezer) door, either, and it seems to be working well--to me, at least!
Well, it's a SubZero model 532. What do I do now? Comment posted on May 07, 2009
Oh, yeah. The top of the affected refrigerator door seem too lean a tad toward the other door, and also seems to hand out toward the kitchen, too, at the top. Comment posted on May 07, 2009
''the affected refrigerator door seem too lean a tad toward the other door, and also seems to hang out toward the kitchen, too, at the top''
The door closes, but does not close well, especially on the top half of the refrigerator door.....
Still need a solution for this problem? Try our Premium Assistance plan
Refrigerator Door Repair
www.ApplianceDrx.comAppliance Repair for Ovens, Washers Refrigerators, Microwaves and More.Refrigerator Parts - OEM
www.AppliancePartsPros.com/PartsHuge selection of appliance parts. Same day shipping. Order now.Refrigerator Repair.
www.RescueAC.biz$19.95 Ser fee great price We'll come today! 504.975.5258Sponsored Links
Clarification RequestPosted by blueextc3221 on May 05, 2009
we'll need the full model # of the fridge so we can pull up a schematic.
Thanks!
Best Solutionposted on May 05, 2009Asker's Rating
TheRepairGur
Rank: Master
Rating: 88%, 6 votes
If the door pops open after you close it, or the door is hard to push closed, the door closing mechanism has probably failed. Make sure you check for the obvious things, such as something sticking out of one of the shelves or orange juice cans rolling around the door shelf area causing the door to bounce back open when the door is slammed.
If you notice any unusual sounds when the door is opening and closing, such as a clicking or grinding sound, your door closer is probably worn.
There are three common types of door closers used in domestic refrigerators and freezers. We list here all three, along with how to access each component in order to change it.
The most common door closers used today are small plastic cams mounted at the bottom of the refrigerator and freezer doors. When you open the door, you cause the door to climb up onto the lower cam. When the door is released, the incline helps the door shut. To view a common door cam kit, click here. You can see how the upper and lower cams each have a hill and valley that work against each other to make the system work.
In order to change these, remove all food in the door, and remove the upper hinge in order to take the door off. Most hinges have a plastic cover that can be removed by prying up on it to expose the upper hinge screws. Usually, the cams mount with one screw -- one on the bottom hinge and the other on the outer door panel. On some models, the lower cam is riveted onto the lower hinge, and it's easier to purchase the lower hinge complete rather than try to drill out the old rivet.
If the cams you are replacing are for the freezer door that has a water line going through the middle of the cam, you not only have to remove the door but you must also disconnect the water line. Most water lines are fed through a channel in the door panel and clamped into place in the dispenser housing. Or, there may be a quick disconnect fitting behind the kick plate or apron on the unit. Once you've installed the new cams, you may want to put a light coating of lithium or silicone grease on the surfaces where the cams meet.
Another type of door closer is actually part of the upper hinge assembly itself. To view this style of closer click here.
In order to change this style, pop off the hinge cover, and remove the screws that retain the upper hinge. From there, pry up on the hinge and pull it through the hole in the outer door panel. If the spring is broken and will not come through the hole, remove the inner door panel. This is a big job so you might want to remove the door and lay it on a flat surface. Fold back the door gasket and remove all the screws around the perimeter of the door until you can separate the inner door from the outer door to gain access to the hinge assembly.
A third type of door closer commonly used is one that is internally mounted to the outer door panel, and you must separate the inner and outer door panel to gain access to the closer. To view this type of closer click here. In this style, the hinge pin actually goes through the closer. The hinge pin has a flat spot on each side of it that meshes with the cams on the closer. To view this style of hinge pin click here. On some Sub Zero units, this closer is mounted to the lower portion of the door and removal of the inner door panel is not necessary.
You rated this solution as ''It was helpful''.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1967
Points
U have older 532 - the external cam gets stuck and the door's hinge pin snaps - there is just enough of it left so the door stays inside the body's hinge bracket's hole, and the washer is gone - u need the lower RH door hinge pin with nylon washer - it attaches to the bottom face of door and the pin goes downward into the closer which mounts to the body at an angle - the much newer ones have the cam pieces that everyone's talking about download www.subzerolosangeles.com/partsview/532-1.pdf
u need parts 0180271 rh door closer, and 3540420 door hinge w/pin bottom RH -- part on page 4-24 picture on pg 4-25 use the picture title "prior to serial no. M824xxxxxx
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Nov 14, 2011
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033347
Points
35540
4U Accept credit cards Act now! Don't hesitate! Additional income Addresses on CD All natural Amazing Apply Online As seen on Billing address Auto email removal Avoid bankruptcy Be amazed Be your own boss Being a member Big bucks Bill 1618 Billion dollars Brand new pager Bulk email Buy direct Buying judgments Cable converter Call free Call now Calling creditors Cannot be combined with any other offer Cancel at any time Can't live without Cash bonus Cashcashcash Casino Cell phone cancer scam Cents on the dollar Check or money order Claims not to be selling anything Claims to be in accordance with some spam law Claims to be legal Claims you are a winner Claims you registered with some kind of partner Click below Click here link Click to remove Click to remove mailto Compare rates Compete for your business Confidentially on all orders Congratulations Consolidate debt and credit Stop snoring get it now Special promotion Copy accurately Copy DVDs Credit bureaus Credit card offers Cures baldness Dear email Dear
friend Different reply to Dig up dirt on friends Direct email Direct marketing Discusses search engine listings Do it today Don't delete Drastically reduced Earn per week Easy terms Eliminate bad credit Email harvest Email marketing Expect to earn Fantastic deal Fast Viagra delivery Financial freedom Find out anything For free For instant access For just $ (some amt) Free access Free cell phone Free consultation Free DVD Free grant money Free hosting Free installation Free investment Free leads Free membership Free money Free offer Free preview Free priority mail Free quote Free sample Free trial Free website Full refund Get paid Get started now Gift certificate Great offer Guarantee Have you been turned down? Hidden assets Home employment Human growth hormone If only it were that easy In accordance with laws Increase sales Increase traffic Insurance Investment decision It's effective Join millions of Americans Laser printer Limited time only Long distance phone offer Lose weight spam Lower interest rates
lower monthly payment Lowest price Luxury car Mail in order form Marketing solutions Mass email Meet singles Member stuff Message contains disclaimer Money back Money making Month trial offer More Internet traffic Mortgage rates Multi level marketing MLM Name brand New customers only New domain extensions Nigerian No age restrictions No catch No claim forms No cost No credit check No disappointment No experience No fees No gimmick No inventory No investment No medical exams No middleman No obligation No purchase necessary No questions asked No selling No strings attached Not intended Off shore Offer expires Offers coupon Offers extra cash Offers free (often stolen) passwords Once in lifetime One hundred percent free One hundred percent guaranteed One time mailing Online biz opportunity Online pharmacy Only $ Opportunity Opt in Order now Order status Orders shipped by priority mail Outstanding values Pennies a day People just leave money laying around Please read Potential earnings Print form
signature Print out and fax Produced and sent out Profits Promise you ...! Pure profit Real thing Refinance home Removal instructions Remove in quotes Remove subject Removes wrinkles Reply remove subject Requires initial investment Reserves the right Reverses aging Risk free Round the world S 1618 Safeguard notice Satisfaction guaranteed Save $ Save big money Save up to Score with babes Section 301 See for yourself Sent in compliance Serious cash Serious only Shopping spree Sign up free today Social security number Stainless steel Stock alert Stock disclaimer statement Stock pick Strong buy Stuff on sale Subject to credit Supplies are limited Take action now Talks about hidden charges Talks about prizes Tells you it's an ad Terms and conditions The best rates The following form They keep your money -- no refund! They're just giving it away This isn't junk This isn't spam University diplomas Unlimited Unsecured credit/debt Urgent US dollars Vacation offers
Viagra and other drugs Wants credit card We hate spam We honor all Weekend getaway What are you waiting for? While supplies last While you sleep Who really wins? Why pay more? Will not believe your eyes Winner Winning Work at home You have been selected Your income
1 Related Answer
TheRepairGur
Chris Z
  • 27 Answers
  • Posted on May 05, 2009
SOURCE: Top of refrigerator just inside the fridge door
The most common door closers used today are small plastic cams mounted at the bottom of the refrigerator and freezer doors. When you open the door, you cause the door to climb up onto the lower cam. When the door is released, the incline helps the door shut. To view a common door cam kit, <a href=" http://www.repairclinic.com/0081.asp?RccPartID=1035 ">click here</a>. You can see how the upper and lower cams each have a hill and valley that work against each other to make the system work.
Another type of door closer is actually part of the upper hinge assembly itself. To view this style of closer <a href=" http://www.repairclinic.com/0081.asp?RccPartID=781123 ">click here</a>.
A third type of door closer commonly used is one that is internally mounted to the outer door panel, and you must separate the inner and outer door panel to gain access to the closer. To view this type of closer <a href=" http://www.repairclinic.com/0081.asp?RccPartID=616347 ">click here</a>. In this style, the hinge pin actually goes through the closer. The hinge pin has a flat spot on each side of it that meshes with the cams on the closer. To view this style of hinge pin <a href=" http://www.repairclinic.com/0081.asp?RccPartID=641650">click here</a>. On some Sub Zero units, this closer is mounted to the lower portion of the door and removal of the inner door panel is not necessary.
Subzero 249RP undercounter fridge not cooling anymore?
Question edited for clarity and typo.
Undercounter fridges tend to get neglected. Pull it out and clean the condenser fins and any vents back there. If that doesn't fix it, it probably needs a refrigerant gas top up.
There is a video that may be of interest.
https://www.google.com/search?q=Subzero+249RP
1helpful
2answers
Sub-zero 550 refrigerator is too cold--icing at boottom near vegetable bins. Temperature is eratic--a lot of variation between top shelf and bottom and frequently shifting and changing.
It is very common for this refrigerator to have a freon leak in the evaporator.
Since you need a EPA license, This is usually beyond the scope for the home owner to repair.
http://www.on-timeappliance.com/subzero.html
1helpful
Water leaking into fridge
Drain system is most likely clogged. The top of the frig is a tray that collects condensation. This runs down a tube down the back of the frig. Remove the tray, clean exit hole and check to see if drain tubing is clogged. Fairly easy to do, just pay attention to what order you take things off and just reverse the order to put back together
2answers
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
7helpful
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
4helpful
2answers
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
2helpful
Thermador Freedom T361T70NNP - French Doors - Condensation
I have the same problem, and thermador stated there was a recall on the hinges. They are replacing the hinges to a newer stronger hinge that will pull the refrigerator doors in tighter. It took three different service companies to find the answer to this problem because I was told Thermador does not want anyone to know about this issue they have.
1helpful
SubZero Model 532 (1994) Refigerator/Freezer:
My SubZero 550 Regrigerator/freezer is not making icecubes. Any ideas
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
1helpful
3answers
Subzero model 650 refrigerator
If the light keeps coming back on and temps are rising in the refer section, then you most likely have an evaporator leak. Check to see if you see either a moist spot or ice on the back wall on the left side of the back wall of the refer. If you do, it's definetly a leak. Call a authorized Servicer.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
