Charged archos mp3 player up overnight will not switch on
SOURCE: MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
SOURCE: zen stone mp3 player not switching on
Mine was also completely dead, with the reset doing nothing! I held the vol+ and the Play button at the same time and it was good to go. Holding just the play button or the vol+ button didnt acheive anything. But as I held both together, It came back to life instantly and I havent had any problems with it (for a week so far).
SOURCE: redgroove mp3 player wont turn on
You have got to reset the MP3 player. To do this you have to use a paperclip (or something similar) to press the button next the hold toggle it should have the word RST.
SOURCE: My Element mp3 player wont turn on
When your player freezes, it will only start up and not play the songs or even the buttons won't respond to your pressing them, it is more like your computer hanging and never coming back to working fine unless you restart it. The first thing you should try to do is read the instruction manual and check where the reset button in your MP3 player is. Take a small pin and push the reset button. This will make you player go off for and then you can put it on again and it will work fine. However, there is a possibility of data loss when you reset. Most of your stored stuff will be gone after reset. Another thing that you can do to retrieve your player is doing a firmware update. Do a refresh of your firmware and see if it works, in most cases, it does. Other options are the same that you and everyone else will try as soon as you MP3 player freeze. That is opening the MO3 player and taking out the battery. Set the battery back and push the power button again. It is always a good idea to do a firmware upgrade right after .you can also open it up and blow on it.
SOURCE: white screen
it is still running, so you will have to just leave it with the white screen, the battery will eventually die, when the white screen is gone, that means the player is off and dead, turn on the system, the battery low notice will come up, charge the system and it should be working again
