Intel Motherboard Logo
Tasrif Ismail Posted on Nov 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motherboard socket 478 261983-001
Conection for P5 power green light, h.d. red activity light and reset button. thanks
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Intel Master 2,226 Answers
  • Posted on May 18, 2014
James Miller
Intel Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447517
Points
2985
Http://www.driversshow.com/drivers-manual/manual-compaq-261983-001-motherboard.html
1helpful
Ms 6541 front panel conection
in the lower right corner to find F-P1 18-pin, 3 rows of 2 cables combined as follows: hard drive LED pin 8-blue, red pin 9; button-black power pin6. white and yellow button pin 7 pin9 ready, green Pin8, not only takes away the reset button cable ready source of power and resets
Diagram put back together
Hello
Not to much information from you . Here is a E-Machine assembly for the motherboard .
The power switch is a 2-wire connection to the Motherboard. The 2 pins on the motherboard it connects to will be labeled something like PW. The polarity on it doesn't matter. There will also be a power LED connection. Usually those wires are green and black. Green is positive. There's also a hard drive activity LED with (usually) red and black wires. Red is positive. Hopefully that polarity will be marked on the motherboard. If not, try it one way and if the LED doesn't light up, try it the other way. The power (green) LED should be on whenever the PC is on. The hard drive (red) LED will be on whenever the drive is being accessed. There might be pins on the motherboard for reset. Some computers don't have a reset button. In that case you wouldn't connect anything to it. If your case does have a reset button then connect the wires to the reset pins on the motherboard. Polarity doesn't matter for that.
Hope this helps
Wire green,r-out, orange l-out , jellow mic- in red mic-power and gray ground i will like to know where i have to conect these wire's thank you
Hi' As you are facing the ASUS A8N-SLI mother board check the light blue colored socket on your left side below , then look at it and you can see a guide when you insert the wire which you mean they where to be connected , Note there is also color codes on its printed board as guide for wire color coding .
2answers
How can i correct the front panel connections
your motherboard has three sockets for the front panel connection:
-USB socket, to connect any front usb ports you might have
-AUDIO socket, to connect speaker/microphone socket on the front of your case
-FRONTPANEL socket, where are connected the turn on/reset buttons, the ide/power leds and the buzzer. To connect all the pin in the right way, refer to the attached picturefranzer_2.jpg
Hope it helped,
Franz
2answers
These cables were not conected. Power led reset led pwr sw hdd led. I have located the connection points i think but not the actual placement.
Here are the connections sockets. The front panel power connection socket is this one marked as C
and here are the connections details for the pins
Mention that the leds (power and hd activity) have no problem in reverse polarity connection. They will not light on. So if you came up with this problem, reverse the polarity.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
Connection between emachines case and motherboard
Most likely the wires are for power, reset, and hard disk light. Touch one pair together momentarily, if your compter comes on then connect those wires to the power button. After the computer is on, connect the other two pair to the hard disk light one pair at a time until you see the light activate when the hard disk is running. Then connect the remaining pair to your reset button.
Lost
and what exactly is the problem ? not switching on ? beeping ?
Front panel wiring
Hi, Maybe we can wing it if you can send an image of the motherboard closeup on the F_PANEL connections and the wires from the front panel itself, or get the specific motherboard model during POST so we can try getting URL of manual. In some instances, the front panel wires are: Green wire, power on green light +, white wire is power on green light -; Red & Black, speaker; Red & white - HDD red activity light indicator where red is HDD + & white is HDD -; Orange & white - Reset Black & White - power on Post back so we can figure things out. Good luck and kind regards.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
