How do I remove the door panel on a 1995 Cougar
Please rate if this helps.
Section 01-05: Trim, Interior
1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION
The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step.
Trim Panels, Door
Disconnect battery ground cable (14301) .
Item
Part Number
Description
Front Door Trim Panel Finish Panel
17B676
Outside Rear View Mirror Control
Door Lock Switch
55928-S55
Screw (5 Req'd)
5
14529
Window Regulator Control Switch
6
23942
Trim Panels,Need to remove drivers door panel - 83b257f.gifbr />
Item
Part Number
Description
Front Door
383356-S100
Nut (2 Req'd Each Side)
56903-S58
Screw (2 Req'd Each Side)
SOURCE: driver door panel removal and re-connect door pull
You most likley have a damaged inside door handle. To remove the door panel, you must first remove the handle bezel. The trim piece around the handle. It is held in place by 4 retainer tabs, take a small flat screw driver, insert it between the bezel and handle. Gently pry away from the handle. If you look in the crack around the handle you will see the tabs. When you get that off, remove the switch assembly by prying up on it gently, unplug the wiring. There are 2 screws in the door panel where you pull the door shut, remove those also. Start at the bottom front of the door panel, pull outward firmly, but not violent. The retainers will come out, you will most likley break some, this is common. The inside handle is about $45 from your dealer. If it is the handle it is held in with 1 rivit, drill it out with a 3/16 drill. Replace the handle, reassemble. Good Luck.
SOURCE: 1995 Mercury Cougar Door Panel Removal
This nearly drove me crazy on our 1994 Cougar.
First
remove the electric switch cover(window and mirror controls). Just pops
out with a pry. Remove the harness attachments You will see a single
screw into the door holding a bracket between door pad and door frame.
Remove it.
Second, remove the door lamp plastic cover at the bottom
rear of the door. You will find a second screw in there on the upper
right corner. Remove it and you are ready. Pull the whole door pad
upward and it comes right off. No popem plastic clips or anything else.
Just 3 or 4 quarter circle retainers that pop over into the door when
you push the pad back down
SOURCE: remove front door panel on 1995 merc grand marquis
http://www.autoclinix.com/Mercury/Front%20Speakers2.htm
SOURCE: how to remove a 1999 civic se left door panel
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
SOURCE: need directions to remove driver door interior panel 1997 deville
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls
why
