This is the eastest way to program your remote.
To program a component using the Automatic Code Search method, perform the following steps:
1.
Turn on the component you want the remote control to operate.
2.
Press and release the component button that corresponds to the component you want the remote control to operate.
The illuminated
ON-OFF button turns on and remains on.
3.
Press and hold both the component and
ON-OFF buttons.
The illuminated
ON-OFF button turns off.
4.
After the illuminated
ON-OFF button turns back on, release both buttons.
The illuminated
ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated
ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained.
5.
PLAY button.
6.
If, after five seconds, the component does not respond, continue to press the
PLAY button every five seconds until the component turns off.
Each time the
PLAY button is pressed, the illuminated
ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated
ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
7.
When the component turns off, press and release the
REVERSE button, then wait two seconds to see if the component turns on again.
If the component does not respond, continue to press the
REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the
REVERSE button is pressed, the illuminated
ON-OFF button blinks.
If the
REVERSE button is accidentally pressed after the component responds, press and release the
FORWARD button. Wait two seconds to see if the component turns off again.
8.
To save the new code, when the illuminated
ON-OFF button turns off, press and release the
STOP button.
If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s
