Is there any water in machine if so the the pump is not turn ther my but an object obstructing the pump I would check the filter and make sure the pump purpler is turning you can check the by turn it with a screw drive it must turn freely make sure you disconnect power first
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
F20 water only problem insufficient water supply open both hot and cold unclog hoses
F21 Drain problem clogged,frozen kinked
SUD excess sud using non he detergent or to much detergent
F22 front door lock door not closed properly
For these select poepwer/cancel twice to cancel cycle
Other f codes select power/cancel twice select drain& spin if youhave excess water
Inside of the solenoid/valve are flaps that open and close upon command from the control center. When dirt, grime, or sand collect, it can keep the valve open or closed. You need to have a Pre-Filter system like a water conditioner to keep debris from entering the machine. In the mean time, remove the water lines Hot and Cold from the washer. If you have a vacuum hose that can blow and suck, do both at the ports on the machine. Clean all hoses out so no debris is inside the walls of the hoses. Tap the in/out ports on the washer with the back end of the screw driver to loosen up any particles that did collect inside the valves. If all looks clean and in order, use a hose screen in the hose attachment to the washer to keep debris out ( available for a few cents from Lowes) , reattach Hot to Hot, Cold to Cold.
Turn on the water valves and try to start fresh. If that fails, you need a professional service agent.
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
The bellows is clogged that can e cleared by opening the door and checking the area just outside the tub at the bottom for debris. Clean this area and should drain normally into outer tub.
