Dishwashers Logo
A
Anonymous Posted on Nov 23, 2013
Replace fuse whirlpool w10289944a
Dishwasher does nothing. no lights. How do I replace the fuse?
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
No lights on whirlpool quiet partner ii -- is it dead?
The main board sends power to the display lights. Check with a multimeter for voltage coming out of the main board to the display board. If no voltage the main board is bad or the fuse is bad.
1helpful
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
1helpful
Whirlpool dishwasher has line voltage in and has power up to the control pad but nothing is working, no light and will not turn on. It was in the middle of a wash when it quit.
This unit has a fuse which is clipped on to the top of the electronic control. If you have an ohm meter, check this for continuity, or with a volt meter check for 120 volts across the the fuse. If you have line voltage or no continuity then replace the fuse.
Jan 14, 2011 • Dishwashers
Does the Whirlpool Gold dishwasher have a fuse?
The fuse is in the control panel on the right hand side after you open the panels 6 screws.
The replacement fuse kit comes with a wire harness that must be used to prevent the new fuse from blowing.
My whirlpool model # DU943PWKQO has power to it, but no power
There is a thermal fuse in the top right corner of the control panel that will need to be replaced.
WHIRLPOOL QUITE PARTNER ii
there is a thermal fuse attached to the main control, check for continuity if none replace fuse.
1helpful
2answers
Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
