Problem with burrs? very hard to assemble, coffee grind is unusably coarse, now can't unassemble to check burr line up
SOURCE: can't disasseble burr set
take an oil filter remoover for cars(the model with 3 legs and gears will do better job). 2 man required one holding grinder other one start turning left and right the upper holder(during turning hold down the brake pin.) it is bit boring and job wich requires patience. but i think you will manage it
here is the diagram:
http://www.partsguru.com/images/Img844.jpg
SOURCE: cuisinart burr grind and brew coffee maker
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
SOURCE: cuisinart burr coffee grinder
The best solution I have was referred to me by a mate of mine who services commercial coffee machines.
Step 1. Remove the base of the grinder... this is actually the hardest aspect of this task... as there is one tamper-proofing screw... if you can't get the correct star-hex screw driver I recommend drilling the screw out.
Step 2. Once the base is off you will see the main shaft of the grinders motor. The shaft has a star washer set in behind hew nut, the end of the shaft has a slot cut into for a flat bladed screwdriver. Hold the nut with a pair of pliers & you can adjust the shaft positioning (& hence the burr attached to the motor) by about 3mm....
You will need to experiment to find the correct level of fineness as you require.
If you need further information send me an e-mail as I'd be happy to forward more detailed instructions.
Good Luck.
Cheers.......
Dave ([email protected])
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
SOURCE: My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
