Pc modem
SOURCE: drivers for HP Compaq Presario V2000 laptop
you can download drivers from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&lang=en&dlc=en&product=500508&
may this help,
melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
SOURCE: need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
SOURCE: missing drivers for compaq presario v2000 machine
SOLUTION!!!
**Even though your computer may SAY that it is a Presario V2000, it may have an entirely different product number for downloading drivers specific to your particular configuration.**
1) Look at the serial code on the back/bottom of your computer: there is a number starting with p/n (ex. p/nEX664UA#APL) This code identifies your computer beyond the V2000 label.
2) Go to the compaq/hp website: http://welcome.hp.com/country/us/en/welcome.html#Support
3) select "Download Drivers and software(and firmware)"
4) THEN, enter your P/N Instead of "Presario V2000" into the product name/number box, and hit enter.
Select your operating system, and you will be redirected to a page listing all the necessary drivers for your model.
On the left of your screen, you will see a box that says "your product" with a picture of a laptop, and a model number beneath it. THIS IS YOUR ACTUAL MODEL NUMBER (Mine was Compaq Presario V2610CA Notebook PC).
5) Download and install the drivers you need, and gappy geeking!!!
G33K_G1RL
SOURCE: can not setup windows xp sp3 sata on hp compaq
Ok, the problem here is that the Windows XP CD that you have does not have the proper SATA drivers on it already. There are two ways to get around this:
1. Locate the drivers for your SATA controller from HP's website. Copy them to a floppy disk (old 3.5" style) and install the drivers during the installation. When booting up the XP CD, one of the first things it says is "Press F6 to install 3rd party RAID or device drivers". This is where you would press F6. During the install, it would ask you to provide the hard drive controller drivers. Windows XP only allows for these drivers to be installed from a floppy disk, so if your computer doesn't already have a floppy drive, you'll need to get an external USB drive. Once you give XP setup the correct drivers, it can find the hard drive and continue with the installation.
2. Create a custom XP installation CD with the new drivers on it. On another computer with internet, CD-burning capability, and a lot of time and effort, you can slipstream the SATA drivers into the XP CD that you have now. This is not a process for novice users, and can be very time consuming. For a single installation, you're better off with the floppy drive option.
In order to find the correct SATA drivers for your computer, we'll need to know the exact make and model of your computer. The Presario v6700 is a series, there are many models inside of that series. They most likely use the same driver for SATA, but it'd be nice to know exactly which model you have. THis should be printed on the bottom of the laptop.
SOURCE: Xp SP3 Sound and Wireless Drivers on compaq presario C700
Please rate if it fixes your issue
Video:
http://downloadmirror.intel.com/1438...2k_xp14311.exe
Chipset:
http://downloadmirror.intel.com/13799/eng/ChipUtil.exe
Realtek RTL8100CL/RTL8110Sb NIC Driver
ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30156.exe
Intel Pro Wireless:
ftp://ftp.hp.com/pub/softpaq/sp33001-33500/sp33404.exe
BroadCom Wireless:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34152.exe
Alps Touchpad drivers:
ftp://ftp.hp.com/pub/softpaq/sp31001-31500/sp31075.exe
HP Help and Support for Microsoft Windows XP :
ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36545.exe
This model of Presario has an audio controller that supports the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
Note: Please copy the entire link starting from "ftp" to "exe" and paste it in the address bar of the browser in your computer and press enter.
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp36090 folder and the double click the X32 folder. Select the .inf file, click open and Continue with the onscreen instructions.
Similarly install Modem Drivers:
Conexant CX20548 Modem Driver for Microsoft Windows XP
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
1.Right click on "Modem device on High Definition Audio Bus" and click Update driver.
2. Select "Install from a list or specific location"
3. Click Next. Then select "Don't search, I will choose the driver to install"
4. Click Next and then select "Modem" from the list.
5. Click Next and then click Have Disk.
6. Click Browse C:\swsetup\sp36089 folder and select the .inf (wis30b2b) file and click open and Continue with the onscreen instructions.
