I bought this white MTD 14.5 ohv hydro one month ago it ran ok but smoked a little no knocks . I changed the oil put new oil filter on and noticed thier was no air filter on it put one on and it smooooookes bad so i took the air filter off and it runs fine but still smokes a little.
Sounds like it's pulling oil by the rings/valves -- the air filter is creating more suction. I would try a small amount of an oil additive for high mileage engines. Follow the mixing/proportion directions on the bottle. Sounds like this engine is "wearing out".
Yes, that would be bad. 5/30 is very "thin" oil. That'll slip right by the rings, etc. I'd use "plain" 30 weight non-detergent. If it still smokes, go with the additive as I described.
It occurred to me that you may have put too much oil in the engine, as well. Those engines ususlly only require a quart (need to check owner's manual). How much did you put in it?
Anything new on this?
Charlie
blue and white smoke
i used mobil one 5 30 oil would that be bad?
ok i will try that today and let you know. thank ypu for your advice.
I put 1.5 qt but drained the half out and it still burned oil.
this was a used mower and did not come with a owner's manual.
I bought Bardahl no smoke plus stop leak.
Charlie this was the first day i used my mower since your information , i used 30 W oil non detergent put 2 oz stop smoke in and what a difference that made . thank you
Blue/white smoke or black smoke?
