The water pipes at the back of my machine are green! Can they be removed/replaced/cleaned?
Hello i hope i can help you? may i please ask you when you say the pipes at the back are green is this green pipes or green with not being cleaned? if they are green due to not being cleaned. open the machine up and check where the pipes are connected. remove the pipes and give them a good clean with with a old toothbrush. and you can use a old rag just push this through a couple off times make sure the rag is soaked in warm water.i hope this will help you?
What kind of machine is this?
The green is oxidized copper -- it can be cleaned off with a wire brush -- but it's usually harmless unless it's in a valve and creating an obstruction or causing something to bind.
