Question about Mitsubishi WS-55311 55" Rear Projection Television
Does the Mitsubishi WS-5551 hve HDMI capabilities
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Posted on Feb 25, 2009
gopakumarg43
  • 76143 Answers
SOURCE: how do i get 1080i, my tv shows im only in 480i. i
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Posted on Feb 05, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: add hdmi port to mitsubishi ws-65807
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Posted on Dec 13, 2012
How do I connect a bluray player to Mitsubishi WS-65313
Check the connections for firmness. If the converter works properly, there shouldn't be any problem other than this.
Jul 09, 2014 | Mitsubishi Televison & Video
Add hdmi port to mitsubishi ws-65807
Dec 13, 2012 | Mitsubishi WS-65807 65" Rear Projection...
What is the best way to conect a HDMI output Blueray player to a Mitsubishi WS--65611
I would Go Component instead if possible---there are adaptors for the HDMI but you are likely to have issues that way as well.
Dec 03, 2012 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-65413 hdmi to component
unless you can find some kind of adapter--no. And for that matter the set has a HD input that is component----HDMI may use less cables but is prone to a lot of issues.
Apr 16, 2012 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi ws-55805 HDTV Control to HDMI
there is a converter box , where you can connect everything and convert in to hdmi output , you can buy this boxes on the internet or at the redioshack
Feb 12, 2012 | Mitsubishi WS-55315 55" Rear Projection...
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mits Ws 5551 won't turn on
http://www.techlore.com/forum/thread/19174/Green-Blinking-Light-on-Mitsubishi-HDTV/?page=26#43124
Go to this post. I had the same problem and it was easy to fix...it cost about 26 bucks total and took about 20 minutes start to finish!
Bruce
Jul 20, 2009 | Mitsubishi WS-55511 55" Rear Projection...
HDMI upgrade card available?
No,it for data recovery mainly.Ur HDMI connection it work?If not tries another HDMI cable usally work.
Apr 11, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi ws-65313 and blue ray
that is a load of bull trying to sell you a newer TV. If your TV has component video inputs, you can easily connect it to a blue ray player. One thing though is that this TV will not be capable of 1080p resolution but will work fine with 720P and 1080i and at 1080i you probably wont even notice the difference. Get the player from bestbuy and run to the closest walmart and pick up a component video cable for less than 20..
Feb 28, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-55311 55" Rear Projection Television Questions
Mitsubishi WS-55311 55" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
