Question about Faberware FCP280 Coffee Maker
8-cup Farberware electric coffee maker
Coffee does not perk long enough and does not get hot. Are thermostats available for home installation? Hate to throw it away as it was a Christmas gift and not very old. Just bought a 4-C pot but it is too small. Are the thromostats interchangeable? Thank you for your help on this matter.
  • 14 more comments
  • phil JB Nov 14, 2007
    I have cleaned the coffee pot very well with with dishwasher soap. It sparkles like new, but still has this problem.
  • Anonymous Nov 20, 2007
    I can hold onto the side of the pot after it quits and have to put the coffee in the micro wave before we drink it. Pot is not a year old.
  • jpls Dec 01, 2007
    I have a problem of the coffee not perking long enough to get hot. suspect thermostat as all connectors appear to be tight and no signs of overheating at the connections..
  • mdsjsb Dec 23, 2007
    I have a 4 cup farberware coffee maker and italso does not perk long enough or and the coffee does not get hot enough. It used to work fine, now it works sometimes, that is it perks but for only a couple of minutes.
  • Anonymous Jan 06, 2008
    Same problem. Doesn't get hot.
  • phylmaguire Jan 12, 2008
    I have the same problem, I have gone through 2 coffee pots within 2 years with the same problem. I remember my mother having the same Farberware coffee pot for years and years never having a problem. I've had to buy 1 a year. The only time I use it is in the morning. don't know how to resolve the problem, if anyone does let me know.
  • Anonymous Jan 15, 2008
    have same problem, coffee not hot and it look like tea
  • Anonymous Mar 25, 2008
    Does not perk long enough to get a good cup of coffee and it is not really hot at first. Is there an adjustment to increase the perking time?
  • Anonymous Oct 23, 2008
    We have a four cup Faberware which is fairly new and it just started making only hot water
  • Anonymous Oct 28, 2008
    8 cup Faberware Electric Coffee does not brew long enoough to make a
    good strong hot coffee. Please help. Coffee pot only 1 1/2 years old.
    Thank You! Veronica
  • keutzerl Dec 21, 2008
    I, too, just acquired a Farberware FCP280. I was very excited about getting it but I'm having the same problem as all the others listed here. Weak coffee. Doesn't perk long enough. Not hot enough. What a disappointment.
    I picked it up at a Gargage Sale and wondered why it looked practically brand new. Now I know. :-(
  • jandrews16 Dec 21, 2008
    I have the 4 cup model and the same problem. This is my second one - and the last. I checked the spring - fine. The washer spins freely. Everything clean as a whistle. Took the bottom off and inspected inside - everything dry and intact. The problem is that the Faberware quality has gone from good to junk. Such a shame throwing away beautiful stainless steel. Saving up for a Newco OCS (made in US) or Technivorm KBT (made in Netherlands).
  • mmdaca Feb 24, 2009
    just heats the water makes a perk sound 1 time
  • Anonymous Apr 20, 2009
    lost intructions for amount of grounds for a 24 cup perc
  • Happy Jan 03, 2012
    Coffee perked but was luke warm. I scrubbed the inside of the pot and the stem that holds the basket , most important was the hole in the bottom of the pot. I had also stretched the spring on the stem for a better fit in the bottom of the pot. Doing all of this gave a better contact of the metals. Which now, I have very Hot Coffee again. Thanks to people here with their suggestions.
  • Anonymous Mar 13, 2014
    Cord is ok
Hi, I just posted this for the FCP412 model: here it goes again.
I've had the same problem, I went with a percolator since our water is hard and we calcify the heating element within about a year. Having the FCP-412 stop working has made me angry as well.
1st, I placed an order for a P04-303 thermostat. It seems to be the correct replacement but we'll see. You can find it here: http://www.goodmans.net/get_item_fa-p04-303_farberware-p04-303-thermostat-for-coffemaker-urn.htm
2nd, here is my 1 cent fix. Really, insert a penny under the thermostat. The delay that it takes to additionally heat the penny will increase the duration that the 1000 Watt element is on. You can experiment with other materials just make sure it isn't flammable (it's next to the element) and it is not too insulate (you want the thermostat to open the circuit some time after the start of the heating cycle (3-3:30 minutes).
Good luck. -david
Posted on Feb 14, 2009
I have a 4 cup farberware electric coffee pot which I have described the problem before. I talked to farberware service and they directed me to make sure the little metal washer/ring on the bottom of the tub moved freely, I cleaned it really good with some automatic dishwasher detergent, and now it works fine. Before it didn't seem to perk long enough, the coffee was weak and the coffee was not very hot. Now it perks for much longer, I can smell the fresh coffee aroma and it almost MAC-D's hot. I thought it was a Thermostat also but the service guy said most times it was that the ring gets gummed up with coffee oils and stuff. It didn't look gummed up but it didn't move freely either. I cleaned it and it's been working great for over two weeks.
Posted on Jan 20, 2008
  • 2 more comments
  • Roseann Sep 12, 2012
    I am in the process of cleaning my 8 cup pot with Dip-It, definitely perked longer and YES the washer was tight! My husband turned it and it is moving freely. After I clean the pot I will make coffee but this sounds like it was the problem! Thank you for posting!
    In the process of cleaning my 8 cup with Dip-It as I type. My husband found the washer to be tight , turned it and it moved freely. It definitely perked longer, once I clean it I will make coffee. Want to thank you for posting this.
  • Roseann Sep 14, 2012
    I am sorry to report the washer fix didn't work. Cleaned it with steel wool, was moveable but this mornings coffee was water and just that!!! Really a shame and I did notice the Dip-IT does not work on the pot like it did yrs ago. I guess it's just poorly made now!
  • Maria Apr 21, 2013
    THANKS for the tip. I thought I kept my percolator clean, but I got that washer to move freely and just brewed a great pot of coffee. Way better solution than jumping to the thermostat first.
I've had farberware percolaters for the last 40 years. I noticed the last 15 years that they don't last very long anymore. I was buying them every year. This time, it went through it's cycle of "tea" colored coffee, then finally died. Since it was going to be ANOTHER pot that I had to trash, I banged it on my tile counter 6-8 times out of frustration - and IT WORKS NOW!!
Posted on Feb 09, 2008
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have repaired a number of Farberware pots using new P04-303 thermostats from Goodmans, Cerini Coffee and others. To make them last, I use silver-bearing solder to bond the round rivet ends to the flats of the electrical spades. It can be done on a used thermostat but it's difficult due to the discoloration and oxidization that occurs during use. If you mod a new thermostat with a couple of drops of well placed solder, well tinned to the rivets and tabs, the thermostat will last a very, very long time.
Posted on Jan 12, 2015
Farberware was bought by a Chinese company and isn't the Farberware your mother used any more. This coffee pot problem is epidemic with no suppor, it is Not a spring problem 99% of the time.. There is a thermostat that controls the electric flow underneath to the heater. Apparantly this is the most likely culprit. Not sure yet where to get another one. It is easily changed with a Phillips Screwdriver. It shouldn't be more than $5 so find one and give it a try. If it is supplied by the manufacturer, it will most likely go again under 1 year. Buy a Newco OCS-8.
  • Diesel Eddie Aug 21, 2011
    Okay, I think we might have helped overcome the Chinese version of the farberware coffee pot. First make sure the spring on the stem is snug and clean making good contact not just slipped on. Second, after removing the little metal spring steel clip holding down the thermostat against the bottom portion of the coffee pot, bend the metal clip so it puts more consistent pressure on the thermostat making giving it tighter pressure up against the pit. ALWAYS use COLD water when making coffee. The cold water shocks the bean when heated to release more flavor and enjoy. My pot when from a 2 min 36 second perk to a 4 min 40 second perk. GREAT COFFEE!
    PS, adding something under the thermostat between it and the pot did not improve things at all i nfact it seemed to shorted the perk time.
Coffee taste "soapy", "plasticly"
Posted on Jan 06, 2008
If your pot heats up but does not perk the coffee strong enough the problem could be the spring attached to the center support that runs up through the grind stainer. I found that if the spring lost it's tension or came off the center post than the basket would not "perk" and the coffee grinds would not blend with the water. Replace the spring and the coffee was fine
Posted on Jan 03, 2008
For solution No.2, is the washer attached to the stem? I have the 8-cup. I cleaned the waster on the bottom of the stem. I have to try it next to see if it works. My coffee was also weak and warm.
Posted on Feb 17, 2009
3 Suggested Answers
SOURCE:
Tech Jenkins
  • 359 Answers
SOURCE: 8-cup Farberware electric coffee maker
Most electronics have a 1 year warranty, if you could find out were it came from you could take it back and get store credit for it. I wish I could help you more, but on this sort of thing I can't imagine there is much you can do other than that.
Posted on Aug 25, 2008
jonniewalker
  • 1031 Answers
.There is a thermostat that controls the electric flow underneath to the heater. that is the most likely culprit. but am not surewhere to get another one. but you can easily changed with a Screwdriver. It shouldn't be more than $8
Do you have an instruction manual that i can download for a 55 cup farberware coffee maker?
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For coffee makers try the e-mail address for Electric Appliances. Send your model number with your request for a manual.
Thank you for using FixYa!
Apr 15, 2011 | Faberware 12-55 Cup Coffee Urn
Aug 25, 2008 | Faberware FCP280 Coffee Maker
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
I broke the pump tube for my Farberware Urn #155-A, 55 Cup. Does anyone have one?
New tubes are available from Goodman's, 10914 NW 33rd Suite 107, Miami, FL 33172. Tele: 305 278 8822. If you broke just the ceramic outer tube, it will still work alright. The purpose of that cermaic tube was to prevent the hot water being perked up the stem from heating the other water that hasn't been perked yet.....
Jan 17, 2010 | Faberware 12-55 Cup Coffee Urn
My Farberware coffee maker starting making a high
Hi Farberware China pots and USA pots perk super fast. That is what making the racket. It will stop when the coffee is ready. bobbyone
Sep 21, 2009 | Faberware 2-8 Cup Percolator
Hi you have a pot made in China, 1 of 2 things are broken. 1 the thermostat, 2 the keepwarm element. 9 out of 10 times it is the thermo.You can not buy them in the USA. I have a auction on eBay and I cab make the parts out ob USA parts. Mt eBay name is ron622c, you can take a look. Go to Farberware coffee pot parts. Good luck. Ron
May 22, 2009 | Faberware FCP280 Coffee Maker
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Won't perk properly
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Oct 21, 2008 | West Bend 13500 Coffee Maker
Coffeepots not operating by not getting hot enough
Hi. Sue, Problem is you're buying China pot's. One of 2 things can cause that problem. The Thermostat or the keepwarm element. 9 out of 10 it is the thermo. The parts are not available in the USA. I have a eBay auction site. I have to make the thermo's out of USA ones. They are 8.00 plus 2.00 S/H. My eBay name is ron622c. If you want to stay with Farberware you can buy a used one or if you are lucky a new one. But don't buy a China one, Good luck. Ron
Jul 06, 2008 | Faberware FCP280 Coffee Maker
Faberware FCP280 Coffee Maker Logo
5,985 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Bob Janelli
Level 1 Expert
ellenskitche
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
