The error oxc19a0021
is mostly occurred in HP printers To solve the error code oxc19a0021,Follow the given steps
Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
Remove the cartridges from the printer
Wait for the 'Insert Cartridges' message to display on the control panel
Disconnect the power from the back of the printer
Now wait 60 seconds
Now reconnect the power If the product does not automatically turn on, press the Power button
Reinsert the cartridges, and then close any open doors on the printer.
If you receive a prompt to print a calibration page.Print it
Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove. But if u face still this error then printer service required.In that condition best option is to Contact HP Service Provider
I hope this solution helps you Thank you for using FixYa
The ink failure error is caused by air in the ink feed tubes in your
printer. This happens when the ink in your cartridge runs out and the
printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair
solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off. Unplug the power cord from the back of the printer. Remove all the ink cartridges. Wait two minutes. Plug the power cord into the back of the printer. Press the On button to turn the printer on. Install the ink cartridges when prompted. If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Ink system failures is a very serious problem on HP printer systems. If
you have this problem you should be ready to replace your printer.
However there are still troubleshooting steps that you can do to try to
resolve this problem. try this Ink System Failure Trouble shooting guide.
