Plumbing Logo
G
Gaby Burse Posted on Nov 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hose burst under stink
I have two identical faucets in my kitchen. Both are 5 years old. One burst under the sink and hot water flooded my wood floor. I need a whole new faucet to match the other one. Kohler A112.18.1, 2.2gpm, 8.3L/min Is there one available? Can't find in HD or Lowes.
  • Carmen Sandiego
    Carmen Sandiego Jan 15, 2014
    I hate it when things like that happen, it seems they always happen at the worst possible moments. Whenever I have something like that happen I just call http://www.rakeman.com/about. They always do a great job fixing the problem.
  • Hannah Schroeder
    Hannah Schroeder Nov 23, 2017
    I'm sorry that one of your sink pipes burst and flooded your wood floor. I'm having a similar problem, except the burst pipes are in the basement, and so far there are four inches of water on the floor. Maybe you've fixed your problem, but I'm going to call a restoration company to fix the damage in my basement. http://www.redeemingrestoration.com/wate...
Grognard
Level 2:
Novelist:
  • Expert 126 Answers
  • Posted on Nov 23, 2013
Grognard
Expert
Level 2:
Novelist:
Answers
126
Questions
0
Helped
33147
Points
345
It is highly unlikely that the faucet failed; it's far more likely the feed tube between the water pipe and the faucet burst. If your faucets were installed 5 years ago, it's likely that they were installed with flexible feed tubes. Reach up under the faucet and unscrew the feed tube, then unscrew the feed tube from the cutoff valve on the water pipe. Take the burst tube to Home Depot and get a new one - it should cost $10 or so. (I would also recommend picking up a small tube of thread seal - it'll look like a travel tube of toothpaste and cost about $3.) Lightly coat the threads of the faucet connection with thread seal and screw the feed pipe onto the faucet as tight as you can with your hand. Do the same at the cutoff valve end with a wrench but do not over tighten. Once both ends are firmly connected, turn the cutoff valve on and check for leaks. If you find any, try to tighten the connections a bit. If you're uncomfortable with any of this, I'm sure there's a DIYer like me in your neighborhood who'd be glad to help out. It's easy and it's quick once you've done it a couple times. Good luck!
  • Anonymous Dec 13, 2013
    Thank you so much for your help. The plumbing service in Santa Barbara CA is one of the best I've worked with in a long time.
  • Carmen Sandiego
1 Related Answer
Anonymous
  • Posted on Nov 17, 2012
SOURCE: brand new kohler cruette. attached cold and hot water fine. when snapping in the pull out faucet hose it sprays all over under the sink
Hi rysenga, the problem is an omission of directions. The section 9 directions are the worst offender and left me never again to purchase a Kohler product. First, this connection for the pull out hose to the outlet fitting should have been a screw on connection. Should have been. Ok it was not, I'll get over it. But the directions never mention having to install the white plastic bushing. Not at all. Nor does it mention that the bushing should be put on the outlet first and then push the hose connection in. This omission is a huge one, but should help anyone else reading this complete the install. Find the oval lip white bushing and install this first on the body, and then just push the connector in. Done.
2answers
Why does my hot water have any pressure/force?
Newer faucets are made to save water by having restrictors in them. Some can be removed, some can't. Phone the maker.
Nov 09, 2021 • Plumbing
When i furn hot water on in kitchen it takes 5 leter water to get hot
quite possible that there is 5 liters of water in the pipes between your water heater and the faucet. if this is unacceptible, install an on demand water heater under the kitchen sink
Aug 18, 2014 • Plumbing
How to replace the stainless steel braded supply hoses for the hot and cold on a kitche faucet grohr
shut off water supply knobs remove hoses with pipe or crescent wrench at the base of the faucet under the sink and knob connections
Jun 28, 2012 • Grohe Home
3helpful
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
1helpful
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
1helpful
2answers
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
How do I disassmble a jado kitchen faucet with
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Aug 31, 2009 • Plumbing
1helpful
2answers
We have pressure on the cold water side but not on the hot. The faucet in the bathroom sink has hot water pressure.
make sure your water valve is working properly undo line and open valve if its working than take apart faucet and check for debri
4helpful
2answers
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
