Washer behaves as many others have described; fills in short, sporadic bursts, then beeps and displays the third light only (error code 32). What do I need to be looking at and what do I need to be looking for? Thanks.
I had the water fill starting and stopping until it gave up, issuing a continuous beep and with the third light from the left flashing. As Ian suggested above, I cleaned up the rusted connections on the over-balance switch. It has solved the problem with my Fisher Paykel Smart Drive 051.
Have you tried unplugging it and plugging it in again?
SOURCE: Top loader beeps every second - lights 3,5,7 & 8 all lit
check the reed switch under the lid,and the oobalance switch under the lower board they may be rusty so the machine thinks the lid is open causing this fault.hope this helps.
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
SOURCE: error code 3E Maytag washer
it overheated... turn it off, wait 10 minutes and take out some clothes
SOURCE: I have a kelvinator excellence 6.5 smartdrive9 top
your machine is a fisher and paykel, just re-badged. now the fault you have is your " OUT OF BALANCE" switch is faulty, probably due to corrosion . the switch is located under the control module which is under your display panel. if you choose i can guide you thru the repair. please reply 4 further help
SOURCE: We have a Fisher and Paykel toploader, smart drive
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
