SOURCE: HP photosmart D7160, ink sys failuar error code:
Hi otissr
If you are lucky, the solution given by HP in the following link will help.
Hope you wouldn't require a service call.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01936219&cc=us&lc=en&dlc=en&product=1156652
Good luck
If my answer is helpful, please give a rating.
luciana44
SOURCE: On my Photosmart D7460 HP
1) connect printer directly to wall
2) try different walloutlets
3) unplug the power from the back of the printer and then press and hold down the power button for 30 sec release the button. plug in the power chord..
4) if it does not work service the product
SOURCE: error code 0xc19a0023 on HP photosmart 3 in 1 printer
In
most cases the printer driver software can have errors while being in use or is
shut down. So to reset remove your printer from the PC and uninstall the
printer software. Now reinstall the printer software and then connect the
Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be
installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken
