I want to change the caller ID settings on the phone as all calls come up as unknown and if I miss a call I can't seem to find out who called me as it shows as private
I have had the same problem. I spent days trying to find the settings within the phone, until i called my service provider. They got my Caller ID working within minutes.
Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
You must have the phone number in your contacts exactly like the number calling you or you won't see it. If that doesn't work, check your settings to see if you allow caller id. If that doesn't work make sure your telephone company has caller id turned on for your phone. Good Luck
Scroll to the menu of the phone, under settings of the phone you will see call settings or call, click to open.
Scroll down you will see send my caller ID, click to select option yes or no, click on the yes button that will remove the unknown caller displaying on the persons phone calling you.
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888.In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
you have to press start. then go to settings,then go to phone.when you do that you should see a tab that says caller id, hit that and change provide my caller id from noone to everyone or my contacts only,, however you see fit
Some network providers are having trouble with caller id. You need to be sure that friends or callers are not putting code for unknown caller. Automatically You receiving as unknown calls. Check Your phone on setting caller id click on show.
